Recently, we're getting this 404 issue on the infragistics theme file.
This line in infragistics.loader.js file couldn't be located:["$path$/themes/$theme$/infragistics.theme.css"]
Is there a reason why the loader is unable to locate the css file with the defined path above?
FYI our current folder structure is: "/Content/ignite-141/themes/infragistics2012/infragistics.theme.css"
Please clarify; thanks.
Hello Shashidhar Dasyam,
Is there anything else I can assist you with on the matter? Please do not hesitate to contact me with more questions.
If I understand your post correctlypathandthemeare variables and you are expecting them to be evaluated before the string is used. Is that correct? If so I don't believe that this is possible in JavaScript:
http://stackoverflow.com/questions/3304014/javascript-variable-inside-string-without-concatenation-like-php
If this is the case, then you could use something like: css:[path + "/themes/" + "theme" + "/infragistics.theme.css"]
If that isn't what you are looking for, please clarify what it is you are trying to accomplish.
Let me know if you have any questions with this matter.
Thanks for your willingness to help me. But I am quite confused with your question about the code.
Its the problem with setting the css path and I mentioned it in my very first post. Here is it again:
This line in infragistics.loader.js file couldn't be located: css:["$path$/themes/$theme$/infragistics.theme.css"]
And If I change the above css path to css: ["/Content/ignite-141/themes/infragistics2012/infragistics.theme.css"], it works.
All I need to know is there any better way other than modifying the loader file as these changes will be lost whenever we get newer versions from Infragistics.
Please let me know, if you still need more info; thanks.
Were you able to resolve your issue? If not, I am still more than willing to assist you. Please provide your project for me so I can give you a solution as soon as possible.
I apologize if I have misunderstood you. Issues like this are much easier for me to solve if I have the actual code to look at. Would it be possible for you to send your project over to me? This would allow me to isolate the issue and find a solution for you as quickly as possible. Please let me know if this works for you, and if not, I will continue to work to find a solution for you. Please do not hesitate to contact me with more questions.
