I see you have released a service update of the Ignite UI library to v2014.2249, which should include an update to an issue I am having with filtering templated combos. However, the latest version is not available with the Custom Build tool in the Download section of the Ignite UI website.
Do you plan to upgrade the version used by the online bundler any time soon, or possibly include a custom build tool with the desktop install versions you release in the future?
Thanks.
I saw this morning that the Custom Build tool was updated with the latest service release, and my issue was fixed.
Thank you very much for your help!
Hello rehemann,
Yes. It’s still not updated.
I’ll let you know once the new version is deployed.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
I just tried downloading a new custom build, but it is still not generating the latest service release.
The download generated is igniteui.14.1.20141.2031.custom.zip, and the file contents are identical to the build I made a little over 2 months ago.
I suppose I am expecting an igniteui.14.1.20141.2249.custom.zip
Hello rehemann ,
There’re no plans at this point to add an option to create custom builds for the IgniteUI product to the Desktop Installer.
However the custom build generator at:
https://www.igniteui.com/download
Should be updated with the new Service release version .
I’ve notified the development team of this and I’ll let you know once the changes are deployed.
