In previous versions, I was unable to use the Default Value option when using a Checkbox in a RowEditDialog. Here is the original post:
http://ko.infragistics.com/community/forums/p/80573/406484.aspx
When I started doing this in 2300, I now receive both a checkbox and a combobox for the same field in the RowEditTemplate. Here is a JsFiddle example of what I'm referring to: http://jsfiddle.net/L2x6b/3/. If you select 'Add new row', the 'Make Flag' field shows up with a checkbox within a combobox.
This issue occurred when I upgraded from 13.2.20132.2055 to 13.2.20132.2300.
Paul
Hello Paul,
Thank you for your patience.
After consulting with our engineers I have logged this behavior in our internal tracking system with a Development ID of 177581The next step will be for a developer to review my investigation and to offer a fix, or other resolution.
I will leave this case open - CAS-141756-R3Q2J1 and update you with any new information after the review. You can also continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
I have been researching this matter and the issue seems to be caused by a change in the igGrid functionality for rendering the row editor template for bool columns - a combo editor is now rendered by default for such a type of column. I am currently discussing this with our engineers and will keep you posted of any additional information regarding this matter.
Thank you for contacting us regarding this issue. I am currently researching the scenario and investigating the change in behavior between the service releases and will keep you posted of any available information.
Please do not hesitate to contact me with any updates or questions in the meantime.
