I am using iggrid in my web application,i enable renderCheckboxes: true and i need to fix check box column.
Please suggest me how to fix the check box column in iggrid .
Thank You
Kiran
Hello Kiran,
I am still following your case. Have you been able to resolve the issue using the suggested ?If you have any concerns or questions, please feel free to contact me, I will be glad to help you.Thank you for choosing Infragistics components!
The column with the RowSelectors is not assigned a columnKey. However, it is enough for you to enable the ColumnFixing feature and that column be fixed automatically. Please refer to my sample for a demonstration.
Hi
http://help.infragistics.com/Help/Doc/jQuery/2012.1/CLR4.0/html/igGrid_Configuring_Row_Selectors.html
<script type="text/javascript"> $(function () { $("#grid").igGrid({ autoGenerateColumns: true, dataSource: source, features: [ { name: 'RowSelectors' }, { name: 'Selection', multipleSelection: true } ] }); }); </script> We used above code for check box in iggrid.Please go through the link and provide me how to fix the header checkbox.
script
type
="text/javascript"
function
"#grid"
true
'RowSelectors'
'Selection'
I am just checking if were able to resolve your issue or had the time to prepare a sample of your data source. If you have any concerns or questions, please feel free to contact me, I will be glad to help you.Thank you for choosing Infragistics components!
I do not see any template that contains html markup like <input type="checkbox">.
The only possibility that you get checkboxes rendered is having a bool datatype in your datasource that is not manually defined as a column but is rather auto generated. Please provide me your datasource in order to investigate it.
