505
Editing grid error message when using checkValue
I have recently been working with igGrid and things have been going well. However, I ran into a problem with a validation message box.
So I have a grid which I set up validation for a column in the features section based on this post I found: https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/89595/best-way-to-validate-for-unique-values-in-a-column-of-the-grid
It worked well except that the error message is half way off the screen. If I use Chrome's inspector I can see the label message box appear in the CSS and they styles set on the label. However, I have tried various ways of overwriting their CSS styles to fix my problem. Yet, none of it worked. Is there a way to edit the style of the error message when using 'checkValue' in the validationOptions?
I have attached a screenshot of the issue and a text file with the setup of my updating feature with the validation code.
Julie
examples.zip
