After saving the iggrid data to database, I wanto to rebind the data to iggrid in jquery. I have written the below code and I am getting the error. For the error info, please refer the screen shot and suggest me the solution.
$("#gridNotes").igGrid("dataSourceObject", data.GetNewNotesList);
$("#gridNotes").igGrid('dataBind');
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
Given the description of the issue it is a bit hard to determine what could be the cause of it. Could you please describe in more detail how you are getting the data and what the grid definition looks like? Some code snippets or a small sample reproducing the issue will help a lot in pinpointing the cause.
I am looking forward to hearing from you!
Best regards,
Stamen Stoychev
Thank you for the response. Your code is working for json. I am using generic list to bind the data to grid.I have tried to bind this after the button click again. I am getting the data into this list,bit not able to bind .Same error.
While we are binding the data next time, seems it is not seriaizing.Please hellp me
Hello Ramesh,
In order to change the data source and/or data bind a hierarchical grid you'll have to make the calls to the igHierarchicalGrid widget. Changing the data source can be achieved with the following:
$("#grid1").igHierarchicalGrid("option", "dataSource", newDataSource);
The hierarchical grid will do the data binding for you so no "dataBind" is needed after the option change.
I am attaching a small sample demonstrating these.
Please, let me know if you have any other questions or concerns!
Thank youfor your response. FYI, both the datasource structures are same. My requirement is I want to rebind my igHierarchicalGrid after button click.Please suggest
