Hello!
I need to register any user selection on a rating panel. I use event valueChange when an user clicks on a rating panel. If an user set the same value which was defined by default, the event valueChange didn't fire because value didn't change really. In this case I can't register rating which an user set. How can I resolve this problem?
Thanks in advance!
If you need an event to fire to be able to achieve what you are trying you can use the jQuery click event:
http://api.jquery.com/click/
Then to get the value use can use the API “value” method:
http://help.infragistics.com/jQuery/2014.1/ui.igrating#methods:value
Please let me know if you have any further questions concerning this matter.
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
I used click method which you proposed and property _i in elements to resolve my task.Thanks for your response!
