I am just testing igGrid for the first time, so I came to http://igniteui.com/grid/overview, copy and pasted the complete HTML code into a new _Layout.cshtml (just added @RenderBody to make it work) in an empty MVC4 Project in Visual Studio Ultimate 2013, I added the new HomeController and Index view, run the application and got this error:
JavaScript critical error at line 1, column 1 in http://cdn-na.infragistics.com/jquery/20141/latest/js/infragistics.core.js\n\nSCRIPT1014: Invalid character
That happens with Internet Explorer 11, if I change to Chrome everything works fine.
What's the problem with IE11?
By the way, if I run the application with Chrome as my default browser when debuggin and then I copy paste the address into IE11, it just works! :) very extrange!
I had the same problem when testing in localhost. what sorted it was to put the js files in local, instead of from http://cdn-na.infragistics.com
Hello,Please let me know if you need any further assistance on this issue, I will be glad to help you.Thank you for choosing Infragistics components!
Hello oktober,
In order to investigate this I would need a sample that demonstrates this issue. It would be highly appreciated if you are able to provide it.
Hi, I found that it works fine if I add my website to the Compatibility View, but, why do I have to do that?
I was not able to experience the behavior you have described. For further assistance on the issue please provide the sample that you use and I will be glad to investigate it for you.
