Hello -
I am currently using the Ignite UI Angular Directives for the igGrid (http://igniteui.github.io/igniteui-angular/)
I am using the Angular Controller method to setup my grid.
My question:
In my Angular JS Controller, is there a way for me to call Methods on the Grid?
i.e.
"#grid"
).igGridUpdating(
"addRow"
, {ID: 1, Name:
"John"
"setCellValue"
, 5,
"ProductName"
"bologna"
Since I cannot use the standard jQuery syntax in my Angular JS controller, is there another way to call these types of Methods on the Ignite/Angular Grid?
Such as $scope.grid.igGridUpdating(...)??
Thank You,
Dominick
Hello Dominick,
Thank you for your reply. Glad to hear that you have the issue resolved!
Just as a bit of additional information, changing a value in the datasource directly is also a possibility in this scenario as Angular's two-way binding should also update the grid.
Please do not hesitate to contact me if you have any further questions regarding this matter.
Hi Petar -
I have found a solution for this.
Here is how it can be done for example:
var grid = angular.element(document.querySelector('#myGrid')); grid.igGridUpdating("setCellValue", ui.rowID, "ColumnID", "NewValueForColumn");
In the HTML of the page, the ID of the igGrid must be myGrid in this case.
I am currently looking into this scenario and will keep you posted of my findings.
