35
Cannot edit URL for Datasource
I clicked on "CONFIGURE" for the datasource on a grid, and inputted an URL, but I needed to change the end of the URL, so I pressed "END" on the keyboard, and a box popped up to ask if I wanted to clear the fields, I said no, and it exited the URL box, so I clicked it again, pressed END, and the box popped up again, it is impossible to edit the URL.
  • 3115
    Suggested Answer
    Hi Adam,
    Currently you should be able to edit the dataSource URL and once you hit enter the value is set.
  • 3115
    Hi Adam,
    We've addressed the issue and will be fixed. Possible workaround will be adding an empty dataSource to the design surface and configure the url correctly, then set the dataSource property of the igGrid to the igDataSource you've just added.
