My script never reaches to the second alert i.e. alert("hi1"). I think there is some problem with my ig.loader any helps??
I have this Report1.igr report that I am trying to display on this Repot.cshtml page but nothing appears except the heading
alert("hi") $.ig.loader({ scriptPath: "@Url.Content("~/Scripts/Infragistics")", cssPath: "@Url.Content("~/Content/Infragistics/")", resources: "igReportViewer" }); alert("Hi 1");
$.ig.loader(function () { alert("hi 2"); $("#report").igReportViewer({ height: 600, renderSettings: { definitionUri: 'ReportingClassLibrary;component/Report1.igr', serviceEndpointUri: "ReportService.svc/ajaxAddress/" } }); });
Hello Khatkar,
I am closing this case now. If you need any additional assistance with this case feel free to post here and I will reopen it for you.
Thank you for choosing Infragistics components
That is ok. I will leave this thread open in case you need to post here.
Thank you
But I have not been working on it.
I will surely ask you again if I needed help.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
I am still not able to reproduce the errors you receive. It is possible that not all the necessary resources are successfully loaded. I suggest that you check /js folder and refer to the help document about Adding the required resources for the igReportViewer if you need assistance on how to do it.
It is also possible to
1) load the resources from the CDN - please check Infragistics Content Delivery Network (CDN) for Infragistics Reporting
or
2) use the combined CSS and/or JavaScript files and look for the Referencing combined CSS and JavaScript files section.
If all the resources are properly loaded and issue still persists please try to isolate it in a sample and send it for investigation.
