1530
IgGrid Resizing issues
PFA the sample, where I have 2 rows the height of the grid is set to 400px. When I drag the columns say first column on to the right side, Scroll bar appears at the bottom of row 1 hiding the first row. However there is enough space for the row 2 to be shown without a vertical scrollbar. Is there any option to show the horizontal scroll bar at the bottom of grid after the 2 rows are completely visible?
Note when contracting the columns, the header caption gets wrapped, even in this scenario though there is enough space for the rows to be displayed, it jus displays one row and a vertical scroll bar.
Unable to get the wrapping caption in attached sample.
We are actually using 2013.2 version of infragistics, when I point to CDN for latest 20132 it throws igGrid undefined. so in sample we have pointed to 20141.
Virtualization Mode = Continuous.
Infragistics version - 2013.2
Kiran
index1.zip
  • 15320
    Suggested Answer
    Hello Kiran,
    I tested your sample and noticed that the grid height calculation is made within 'dataRendered' event based on the following formula: $gridHeader.height() + totalRowsInHeight + 4
    However since on Resizing appears horizontal scrollbar that also takes certain space in the grid, which is about 20px, then you may modify this formula like for instance: $gridHeader.height() + totalRowsInHeight + 25. I'm attaching your sample back with some modifications for your reference. If you have further questions, please let me know.
    Tsanna
    index1.zip
  • 15320
    Hello Kiran,
    I'm currently looking into this matter and will keep you posted.
    Please do not hesitate to contact me with any updates or additional questions regarding this matter at the meantime.
    Tsanna
