435
create comboboxes programmatically at runtime?
Is it possible to built multiple comboboxes at runtime programatically? I'm doing:
  var root = document.getElementById('root');
        var selectLength = document.getElementsByTagName('select').length;
        var selectlist = document.createElement('select');
        selectlist.id = "select" + selectLength;
        selectlist.onclick = 'alert();';
        var ops = new Array("first", "second", "thrid", "fourth", "fifth");
        for (var i = 0; i < ops.length; i++) {
            var o = document.createElement("option");
            var t = document.createTextNode(ops[i]);
            o.setAttribute("value", ops[i]);
            o.appendChild(t);
            selectlist.appendChild(o);
        root.appendChild(selectlist);
And need the ability to add multiple comboboxes.  I may need to create 10 or more boxes based upon the selected value of the prior selected value,  Can this be done using the igCombo?
