170
Check Boxes in Iggrid Look Like disabled
Is there a way to change the settings in the grid so that the  checkbox looks disabled,
based on values(true/false) of a field the check box is either checked or unchecked.
but when the value is false, how to make check box look as disabled.
Regards
Raghu
  • 20255
    Let me know if I may be of further assistance
  • 20255
    Hello Raghu,
    Thank you for your question.
    This behavior is by design of our igGrid widget, so my suggestion is to stick with that approach, although if you want to perform some custom solution where you can set disable or enable look of checkboxes please have a look at the following forum thread where Martin is explaining similar scenario.
    http://ko.infragistics.com/community/forums/t/64525.aspx
    Let me know if I may be of further assistance.
