I'm trying to get a simple example sparkline working using the specific javascript files that are required.
When it hits the line to create a sparkline for the element, it errors out saying "Cannot read property '$type' of undefined" somewhere in chart_sparkline.js.
If I use the all encompassing scripts (namely, core, lob and dv) it works fine.
The js files I'm including:
infragistics.util.jsinfragistics.datasource.jsinfragistics.dv.simple.core.jsinfragistics.templating.jsinfragistics.ui.basechart.jsinfragistics.ui.sparkline.jsinfragistics.chart_sparkline.js
Any ideas as to what the problem might be?
Thanks in advance for any help.
I added a JS Fiddle demonstrating the issue. If you comment out the core, lob and dv files and uncomment the recommeded individual js files, you will see the behavior I'm noticing...
http://jsfiddle.net/k0f2njnq/1/
I have investigated your issue and I have asked our engineering staff to examine this further. I have logged this behavior in our internal tracking system with a Development ID of 186200. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution. You can continue to send updates to this case at any time.You can view the status of all development issues connected to this case from the "Development Issues" tab, when viewing this case on the "My Support Requests" page of our website.
Your case for this is CAS-148141-Z2Y9Q2.
I just wanted to give you a quick update that we reproduced the issue and will let you know as soon as we have any new information.
Thank you!
