Any idea why this is not working
<div id="combo"></div><button onclick = SetValue>SetByValue</button>
<script> $(function () {
var data = [ { "ID":1, "Name": "John Smith", "Age": 45 }, { "ID":2, "Name": "Mary Johnson", "Age": 32 }, { "ID":3, "Name": "Bob Ferguson", "Age": 27 } ]; $("#combo").igCombo({ dataSource: data, //JSON Array defined above valueKey: "ID", textKey: "Name", itemTemplate: "<div>${ID} - ${Name}</div>" }); }); function SetValue(){ var item = $("#combo").igCombo("itemByValue", "2"); $("#combo").igCombo("selectedIndex", item.index);
} </script>
I want to select combo based on value. According to this post it should work http://ko.infragistics.com/community/forums/p/68712/347998.aspx
-Manish
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Manish,
Thank you for contacting Infragistics Developer Support!
Please refer to the following, I believe it might be help to resolve your issue. Also as I can see you are trying to select item with value of type string - "2", but I am not able to see any keys of type string for your combo. Your value type should match the type of your key.
Please let me know if you have any additional questions.
