HI
I am using Jquery validation frame work for doing the required field validation for combobox. Below is the infragistics rendered html and it has hidden input element(I believe this has been added for applying the validations), My validation happend on that input element and label displayed next to that element, Due to this error label got over lapped with the actual control. Can you please tell me what is the solution to get the error message properly displayed.
<span data-resourcekey="ENTERAUSERNAME" data-resourcevalue="" data-controlid="11789" data-controltype="igCombo" data-datatype="A" id="AssignUserComboBox" class="ui-igcombo ui-state-default ui-widget ui-corner-all" style="overflow: hidden; display: inline-block; position: relative; width: 100%; height: 23px; min-width: 39px; min-height: 0px;">
<input name="AssignUserComboBox" type="hidden" data-rule-required="true" data-msg-required="You forgot to enter a username." value="" aria-required="true" class=""><label for="AssignUserComboBox" class="error" style="display: none;">You forgot to enter a username.</label>
<span class="ui-igcombo-fieldholder ui-igcombo-fieldholder-ltr ui-corner-left" style="float: left; position: absolute; width: 96.94244604316546%; height: 21px; background: rgb(255, 255, 255);"><input class="ui-igcombo-field ui-corner-all valid" style="float: left; position: absolute; width: 99.81447124304268%; height: 19px; display: block;" aria-invalid="false"><span class="ui-igcombo-clear" data-id="2" tabindex="-1" unselectable="on" title="Clear value" longdesc="Clear value" style="float: right; outline: 0px; display: none; height: 21px;"><span class="ui-igcombo-clearicon ui-icon-circle-close ui-icon" tabindex="-1" unselectable="on" style="outline: 0px; margin-top: 3px;"></span></span></span><span class="ui-igcombo-button ui-state-default ui-igcombo-button-ltr ui-corner-right" data-id="1" tabindex="-1" unselectable="on" title="Show drop-down" longdesc="Show drop-down" style="float: right; outline: 0px; height: 21px;"><span class="ui-igcombo-buttonicon ui-icon-triangle-1-s ui-icon" tabindex="-1" unselectable="on" style="outline: 0px; margin-top: 3px;"></span></span></span>
Could you please let me know if I may be of further assistance.
Hello Paruchuri,
I hope I understand you correctly, if not could you please let me know. You want to submit two html elements (igCombo and input for example) on submit button click. In that case my suggestion is to customize a little bit validate function implementation. You can check if the element, which error message will be displayed, is undefined and if it is, to append the error message to the input element of the igCombo, if it is not, insert it after the 'element' which is passed as parameter.
You can find a code snippet and the modified sample below.
Code snippet:
Thanks for the replay,
I have one more question, what if I have text box and combo box in a single form, then how to call validate () on form.
In addition, below you can find in bold the exact change that I've made. Also the modified sample is attached.
I've tried your suggestion, although the overlapping doesn't appear.
