250
Upload data to igGrid using fileUpload
I am trying to implement a functionality in which i will be uploading an excel sheet, server will go through the sheet, create a List<List<Object>>, where every List<Object> will represent a row. Idea was, server will return this, and I will parse this at client side, and then i will use
$('#grid1').igGridUpdating('addRow',myObbject);
But, i am not able to retrieve any server response apart from retrieving information, whether FileUpload is successful or not. How can i read the server response. I tried following, but this also did not help
$('#grid1').igUpload('getFileInfoData');
My client side in JavaScript, and server is in Java, I am hitting an endpoint using uploadUrl.
Any other idea for implementing the requirement (Upload data to Grid from file) is also welcomde
  • 250
    For a workaround, what i am doing is, on iguploadfileuploaded, i am calling the server again, and fetching the updated row object from server and then calling the    $("#grid1").igGrid("widget").igGridUpdating('addRow',rows); for updtaing the rows. It is working fine
