In this JSFiddle (http://jsfiddle.net/fqm5Lhp7/1/) you can see that when you click on the 'Delete Row' button and filter values using spacebar, the first row in the grid is automatically selected. This behavior can be more precisely pinpointed to pressing spacebar when you have never selected a row in the grid. (you can clearly see this if you immediately press spacebar in the filter when the JSFiddle loads) I have noticed that this behavior was not present in previous versions. (You can see this if you change the script references from 20141 to 20131)
Is this a bug? Is there a work around to avoid selecting rows with spacebar when filtering? I have already created a seperate ticket to ask how to disable the spacebar selection trigger for the grid.
Hello Tsanna,
Thank you for addressing this issue. We look forward to the next service release so that this problem is solved.
Hello Michael,
There was a similar issue addressed in v14.1 and later, however it was fixed and will be officially available in the next service release of v14.1 and 14.2. Here you can get information about the service releases schedule: http://ko.infragistics.com/support/service-releases
At the meantime you can download a partially tested build from the following link: http://builds.infragistics.com/products/IgniteUI/2014.1/IgniteUI_20141.2602_SR.zip before the official service release is officially published.
If you have further questions, please let me know.
Tsanna
