The subject explains what I'm trying to do:
igGrid with fixed row virtualization, grid set to dynamic height (a hack), and some of my columns justified right.
This might be a bug, or maybe I'm just not setting something up right. I found a workaround and it is included in the jsfiddle (you'll have to remove the comment line that I added to fix it to see it work.
Here's the abbreviated code to describe how I'm set up:
$("#grid").igGrid({ autoGenerateColumns: false, width: "100%", height: "600px", rowVirtualization: true, virtualizationMode: "fixed", avgRowHeight: "43px", columns: [ { headerText: "Product ID", key: "ProductID", dataType: "number", width: "15%" }, { headerText: "Product Name", key: "Name", dataType: "string", width: "40%" }, { headerText: "Product Number", key: "ProductNumber", dataType: "string", width: "30%" }, { headerText: "Make Flag", key: "MakeFlag", dataType: "bool", width: "15%" } ], dataSource: adventureWorks, dataRendered: function (evt, ui) { //Original way that infragistics forum post showed how to right align. //ui.owner.element.find("tr th:nth-child(1)").css("text-align", "right"); //ui.owner.element.find("tr th:nth-child(1)").css("text-align", "right"); //RIGHT ALIGNMENT: this is the way I figured out how to do it once I enabled virtualization/fixed. $("#grid_ProductID").css("text-align", "right"); $(ui.owner.element[0]).find("tr td:nth-child(1)").css("text-align", "right"); },......
The bold code above shows that I'm set up with virtualization, a fixed height, and in the dataRendered event, I found a way to right align the text in both the header and the row data.
The problem is, I don't like the fixed height on the grid. If I set it too small, my users that work with a maximized window complain that they can't see more rows at once. If I make it too large, users that do not maximize their window have to scroll the browser to see the whole grid, in conjunction with the grid scrollbar, it's a pain. I'm sure you get the idea.
I came across this post: http://ko.infragistics.com/community/forums/p/90651/447960.aspx#447960
The code below is the working version. When the grid height is set, anything in the dataRendered event is lost. So the text-align has to be redone. Perhaps I'm using the wrong event? dataRendered is the event that I saw in the forum to use to set up this sort of thing. It wouldn't surprise me is not the best place for this.
function setGridHeight() { $("#grid").igGrid("option", "height", $(window).height() - 120); //RESET the text-align here because it is lost during the resize of the grid. $(".ui-iggrid-virtualrow").find("td:nth-child(1)").css("text-align", "right"); //pretty sure the class I'm using is only going to work with virtualization enabled}
$(window).resize(function () { setGridHeight();});setGridHeight(); //set the initial size of the grid.
Here's the fidde: http://jsfiddle.net/uszr4hsw/3/
Hello TRE,
I created the following case for you: CAS-153175-Z5P4L5 and will update you through it. You could see it in your account in the 'Support Activity' page.
Please let me know if you need any additional information.
Yes, fortunately, I'm waiting on yet another unresolved issue to be answered. I had time to go in and reproduce....
Here are steps to see what I am talking about:
This link is modified from my original fiddle above.
I am selecting only the first row from the adventureWorks datasource to put in the grid to show that the continuous virtualization stretches the single row to the whole grid.
It looks silly like that. Especially when you select it for edit (huge text boxes).
Then after clicking done, the row shrinks back down to a normal size (probably what the original row size should have been).
http://jsfiddle.net/uszr4hsw/5/
Thank you for getting back to me.
Did you have the chance to reproduce the issue in an isolated sample?
Please let me know if you need any further assistance with this matter.
I have it on my todo list to try to reproduce the problem that I'm having with the continuous mode virtualization in a portable sample that I can share.
I'm currently working on a problem I am having with the igCombo on a different thread.
I'll be back...
