I need to do a chart with a date for xAxis and time for yAxis.
For example :
date : 1 may 2015 - starttime : 08:00 - endtime : 17:00
date : 2 may 2015 - starttime : 09:00 - endtime : 17:30
How can i achieve this ?
My datasource is a XML retreived with a webservice.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Pascal,
Thank for posting in the Infragistics community !
In order to achieve this you need to define your Xaxis to be of type CategoryX and your Yaxis to be of type numeric. Since the value for time (starttime : 08:00 - endtime : 17:00) are not numeric you will need to convert them to miliseconds and provide these values to the igDataChart. It depends on your scenario wthere you will convert those values on the server, or on the client.
Your chart will look similar to the second one here:
http://www.igniteui.com/data-chart/range-category-series
However in the xAxis you will see dates displayed, and on the Yaxis you will see the miliseconds displayed. You will want to format the yAxis labels and display human friendly value, corresponding to the milisconds value. This can be achieved using the formatLabel optiuon.
Please go ahead and try the suggested. Do not hesitate to contact us if you face any troubles implementing this approach.
