I'm developing a web application and I'm using a lot of grid. I'm trying to avoid having a lot of customization for each one of them. I'd like that the grid set each column's initial width based on the content. I. e.:
Short name NameJF John FooAB Ana Bar
All values for 'Short name' are 2 chars long, and the longest value for 'Name' is 'John Foo' with 8 chars. So in this case, the grid should set 'Short name' column's width to 20%, and 'Name' column's width to 80%.
In case this functionality does not exisist, could you give me some clues so I know where to start building it?
Thanks,Diego
No, now it's working.
Thanks!
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Kind Regards,
Petko Zhekov
Software Developer
Infragistics, Inc.
I haven't received any emails, so I hadn't seen it.
I'll download it and give it a try.
Thanks Petko!
I wrote you in the case. Did you have the chance to see my message? You can see it in the ACTIVE CASES tab in the Support Activity section in your account.
Kind regards,
Hello.
I just wanted to check if you had seen the error and if its bug or I am using it wrong.
