Dear Support Team,
for igGridUpdating I have implemented my own Editor provider. It is using a textarea as the underlying editor. Editing works fine. But when pressing the TAB key, igGridUpdating is not moving to the next editable cell, like it is doing when using the default editors provided by ig.
My special handling of key 9 in onkeydown handler is just forcing that the changes get stored. What do I have to do to let igGrid move to the next editable cell in the table like it is doing when using the standard editors?
Hint: When pressing enter the navigation works. I have handled key code 13 not to move to the next row but to add the new line to the textarea and continue editing the current cell.
I have attached the java script code in the zip file.
Thanks for your help!
Michael Timpe
Hi Michael,
Thank you for your suggestion! We will make sure to describe the process of creating a custom editor provider in more details!
Thank you for choosing Infragistics!
Kind regards, Petko Zhekov Software Developer
thanks. This helped. Would be nice, if you can put this into the documentation.
Kind Regards
Michael
Thank you for posting in our forums! I really appreciate the code that you provided. After I took a look at it I found the cause of the issue. The section where you handle the Tab key press you call endEdit. I remove this line and called _nextEdit method instead. I modified your code and prepared a sample page to demonstrate the approach.
I hope this helps!
