I experiment with the modules infragistics.gridexcelexporter for exporting from an igGrid.
As the igTreeGrid is based on the igGrid, I tried using this module with an igTreeGrid and as you probably guest, it didn't work.
Do you plan to support this feature, is it already possible or do you have a code sample that export flatten hierarshical data into excel using the JavaScript Excel Library?
Hello Pierre,
We received your request and are processing it through our support system. Let me know if you need further assistance regarding this topic.
Best regards,Martin PavlovInfragistics, Inc.
Hello Martin,
I managed to build something combining some of your JavaScript Excel Library sample, but had problem making it work in Firefox and Chrome.
I found and fix some bugs in the JS files. I will post a support request with the details.
Export to Excel for the igTreeGrid is not available in 15.1, but will be supported in 15.2.
It's possible to export the igTreeGrid with the JavaScript Excel Library, but we don't have such sample.
