435
Event not firing
Hello Expert,
I have a HierarchicalGrid that created on demand(LoadOnDemand). The number of depth is unknown. I would like to attach the event 'ighierarchicalgridrowexpanding' to the grid. However, I only able to get the event to fire at the Top table, the children table doesn't fired any events.
Please help, I need this ASAP to complete the requirement.
Thank you
  • 15320
    Hi Phong,
    Did you manage to resolve your issue? If I can provide you with further assistance, please let me know.
    Tsanna
  • 15320
    Hello Phong,
    I tested similar behavior and the 'rowExpanding' event fires properly on my side for all grid levels. If you copied the event definition from our online API: http://help.infragistics.com/jQuery/2015.1/ui.ighierarchicalgrid#events:rowExpanding you should note that jQuery 'live' method for attaching an event handler is deprecated since jQuery v1.7. Instead you can use jQuery 'delegate' method, for instance:
    $(document).delegate("#grid1", "ighierarchicalgridrowexpanding", function (evt, ui) {
    I'm attaching the sample that I used to test this event for your reference. Please take a look at it and if it does not demonstrate correctly your scenario feel free to modify it and send it back to me.
    Tsanna
    hieararchicalGridLoadOnDemand.zip
