Currently the menu is closed from starting but,
How can make the menu already auto opened ?
I want the menu all the way already opened.
Thank you
Hello Eric,
You can suggest this as a new product idea for future versions at <http://ideas.infragistics.com>.
Steps to create your idea:
1. Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The benefits of submitting the product idea yourself include:
- Direct communication with our product management team regarding your product idea.- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the product idea system include:- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.- Allow you to shape the future of our products by requesting new controls and products altogether.- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Previous issue was solved. thank you very much.
Is it possible to disable the click on the center button ?
Sorry, i can't find it in API doc for disable center button clicked.
Please refer to the following API docs => http://help.infragistics.com/jQuery/2015.1/ui.igradialmenu#options:isOpen.
Thanks for your response.
Which part i should change to isOpen: true ?
Below is the starting code.
// create the radial menu
$("#radialMenu").igRadialMenu({
width: "300px",
height: "300px",
items:
header: "Home",
iconUri: "http://www.igniteui.com/images/samples/radial-menu/Bold.png",
click: function () { toggle("main"); }
header: "About Us",
iconUri: "http://www.igniteui.com/images/samples/radial-menu/Italic.png",
click: function () { toggle("AboutUs"); }
You can set isOpen property to true.
Let me know if you need further assistance.
