130
Prevent columns from showing in IgrColumnChooser list
I have a few columns I don't want users to be able to show/hide. Is there any way to prevent a column from showing in IgrColumnChooser. I'd also like to prevent it from being hidden from the column options in the column header.
It seems like it should be a prop on the column itself (something like isColumnHideable).
  • 7595
     Hello Charles,
    Currently we don’t have any API to  prevent columns from showing in IgrColumnChooser, its a new feature idea for us .
    You are right it should be a property on the column itself to enable or disable column being showing in the column chooser like other platforms have.
    For react its a feature we need to implement .You can suggest this feature /prop ideas for future versions by emailing ideas@infragistics.com
    Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: https://ko.infragistics.com/community/ideas
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case.  You can also link back to this thread for additional details.
    Thank you in advance   to submitting your product idea.
