590
Facing issue while moving column sequencing with Mouse.
Hi
I want a small clarification on one of the use case related to IgrDataGrid, i.e https://ko.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid/overview
I have used IgrDataGrid, in that I'm trying to move the column to change the sequencing but sometime I'm facing the issue and I'm not able to drop the column. I'm also able to reproduced the same in Infragistics website react grid.
Case : When we click on any column and try to move then sometimes facing this issue.
Please refer the video.
So, for this I need to know how can I fixed this in our grid.
Hoping for a positive response.
Thanks!!!
  • 29105
    Hello and thank you for contacting Infragistics. I've reproduced the behavior dragging the column headers. It appears specifically when you click the near edge of the column, drag above (away) and then move back into the grid area.
    I've created a private support case, C-00232981, and a new development issue. You can access the new support ticket after signing into your account on the Infragistics website, here: https://account.infragistics.com/support-cases.
    From there if you have any questions feel free to respond to the ticket. Thank you.
