590
Want to know an event to get updated column sequence.
Hi
I want a small clarification on one of the use case related to IgrDataGrid (https://ko.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid/overview).
I have used IgrDataGrid, in that when I change the column sequence then I want the updated sequence of columns. So please suggest an event which I can use to get the updated column sequence after changing it.
Hoping for a positive response.
Thanks!!!
  • 34830
    Hello Shubham,
    I am under the impression that by “changing the column sequence” you mean that you are moving columns. If this is the case, I would recommend using the actualColumnsChanged event of the IgrDataGrid. A sample event handler for this looks like the following:
        public onActualColumnsChanged(s: IgrDataGrid, e: IgrGridColumnsChangedEventArgs){
            for(let i=0; i<e.columns.count; i++){
                let column = e.columns.item(i);
                console.log(column.field);
    The e.columns collection above will reflect the new order of the columns.
    I hope this helps. Please let me know if you have any other questions or concerns on this matter.
