Hi
I want a small clarification on one of the use case related to IgrDataGrid (https://ko.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid/column-filtering)
Here I have used Advanced filter in the grid, In that I want the advanced filter should by default to "contains".
So, for this I need to know how can I achieve that.
Hoping for a positive response.
Thanks!!!
Hello Shubham,
Unfortunately, what we're seeing as expected behavior is actually something we'd consider as a potential new feature. This has been discussed here: https://ko.infragistics.com/community/forums/f/ignite-ui-for-react/126344/wants-to-set-advanced-filter-by-default-to-contains?focus=true ragdoll hit
Unfortunately the expected behavior is a new feature idea for us. It been mentioned here:
