Hi,There is an issue using Filters.
When the user on the page where the IgrGrid is initialised with IgrGridToolbarActions it does work well until the user tries to go to other page (change the route). Then the project crashes with the blank screen and withe the next error message in the developer console:
@infragistics_igniteui-react-grids_grids_combined.js?t=1715001007523&v=8817f177:930 Uncaught DOMException: Failed to execute 'removeChild' on 'Node': The node to be removed is not a child of this node.
The issue only occurs when the IgrGridToolbarActions component added to the IgrGridToolbarDependencies: "react": 17.0.2"react-router-dom": ^6.17.0
Hello Constantine,
Thank you for following up!
Upon further investigation, it appears that the support section exclusively includes private support cases that are created via the "New support request" button. I apologize for any confusion caused by my previous response.
Additionally, regarding the reported behavior, I have investigated this matter, and the issue is scheduled for resolution during the current sprint, May 27th – June 7th. Any new information along with the progress in resolving it can be expected in this time frame. I will ensure to keep you informed via this forum thread.
Please feel free to reach out if you need any additional information or have additional questions regarding this matter.
Looking forward to your reply.
Sincerely, Riva Ivanova Software Developer
Thank you for your answer. Currently I can't see any cases under "My cases" lists. Instead I see "You have no active cases"Best regards. Constantine Golub
Thank you for posting in our community!
I have investigated this matter and determined that your findings are correct, and the behavior is reproducible when using the IgrGridToolbarActions. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 31231.
You can view the status of the development issue connected to this case by clicking on the “Support” tab under “My Cases” list with “In Development” label.
After our development team has reviewed and examined this matter further, I will update you with any new information.
Please let me know if you need any further information on the matter.
