1375
Regarding validation not working properly in grid when editing/adding.
Hello sir/mam,
I need to validate that combination of two columns i.e. location of action and action_id should be unique. I m saving them in a map to check for duplicate. I have a customer editor the 8d action column become text field/combo box on change of checkbox. So I need to validate them when any value is change or user is finished entering the text value I'm that's column or when value in drop-down is changed in case of combo box. It should validate on change of both columns.  I am attaching sample file where you can test and fix it.
It should work on add as well as edit. Please help me fix it and when editing and saving data same as other row save is not working for me not giving any error but saving previous data in grid.
test.zip
  • 800
    Hello Rohit,
    I have been looking into your question, and what I can say is that it seems related to the following one here, with the difference that the latter says that only the Add row operation is not working as expected. A possible approach has already been provided there. I will extend the sample a bit so it demonstrates how such a check can be achieved and provide an answer in the other post.
    Also, I noticed that the same question is asked in the following forum post here as well.
    As previously discussed, duplicating your questions across multiple forum posts is not recommended, since it is hard to manage and leads to confusion. Please avoid duplicating your question. This is for better consistency and history tracking.
    An answer to your question can be found here.
    Sincerely,
    Riva Ivanova
    Software Developer
