I'm having trouble getting the default option for a drop down item to work when running a prototype. In design mode, the drop down is collapsed, and I've set a hint for the drop down. But when I run the prototype it is automatically selecting the first option.
The interaction I'm attempting to mockup is a series of drop down menus, so I've set the state to change when the user makes a selection. I want to leave the drop down blank until a user picks an option.
I believe I've used this same approach in earlier versions of Indigo and it worked, has anyone else seen this since updating recently?
Thank you for sharing such a useful article, defiantly i will share to my friends and WhatsApp groups -
best seo expert in dubai SEO freelancer in Dubaiproperty golden visa in dubai
The topic of Drop Down Default Option is crucial for enhancing user experience. Just as selecting a default option can streamline choices, having clear insights into the real estate market can guide homebuyers effectively. For example, knowing what a typical commercial real estate commission for buyer agencies is can help clients make informed decisions right from the start. Additionally, the 2025 housing market predictions can serve as a valuable resource, setting expectations for future investments. And don't underestimate the importance of tools like the Ohio real estate license lookup, which can clarify the process for homebuyers, similar to how a well-designed dropdown simplifies user navigation.
I'am trying to use the earlier Indig versions but i need each one to stay blank, so i will try it automatically then i selects the first option in the In design mode. milfycmobi.com
I'm experiencing issues with setting the default option for a dropdown in a prototype. In design mode, the dropdown is collapsed with a hint set. However, when the prototype runs, it automatically selects the first option. The interaction involves multiple dropdowns; I need each to stay blank until the user selects an option. I've used a similar method in earlier Indig versions. https://monkeymart.one/
Thanks George, that did address my question. I think my issue was that I had the dropdown in a screenpart, and the screenpart had the first item in the dropdown selected. I had to go back into the source screenpart and change the template to select the hint to resolve the issue.
