15
Code Generation using VSCode extension fails
We are exploring Indigo Design and have tried to generate Angular code(via isual Studio Code extension) for the Sketch file uploaded and published to Indigo Design.
When we import the URL into the extension, the code generation updates existing files such as package.json/angular.json but does not generate any components/modules for the sketch file.
Following are the errors we see in the extension.log:
[3/22/2019 17:50:17] [Info] Successfully generated code.
[3/22/2019 17:50:18] [Info] Executing subprocess 'ng g module infragistics-imports --dry-run=false' with working directory /Users/wes/appindigotest/indigo-app
[3/22/2019 17:50:18] [Info] 'ng g module infragistics-imports --dry-run=false' exited with code 127
[3/22/2019 17:50:18] [Error] Module InfragisticsImportsModule failed to generate.
[3/22/2019 17:50:18] [Info] Executing subprocess 'ng g module negotiate-page --routing --dry-run=false' with working directory /Users/wes/appindigotest/indigo-app
[3/22/2019 17:50:18] [Info] 'ng g module negotiate-page --routing --dry-run=false' exited with code 127
[3/22/2019 17:50:18] [Error] Module NegotiatePageModule failed to generate.
[3/22/2019 17:50:18] [Info] Executing subprocess 'ng g module negotiate-page/negotiate-page-routing --flat --dry-run=false' with working directory /Users/wes/appindigotest/indigo-app
[3/22/2019 17:50:18] [Info] 'ng g module negotiate-page/negotiate-page-routing --flat --dry-run=false' exited with code 127
[3/22/2019 17:50:18] [Error] Routing module NegotiatePageModule failed to generate.
[3/22/2019 17:50:18] [Info] Executing subprocess 'ng g component negotiate-page/negotiate-component --module negotiate-page --dry-run=false' with working directory /Users/wes/appindigotest/indigo-app
[3/22/2019 17:50:18] [Info] 'ng g component negotiate-page/negotiate-component --module negotiate-page --dry-run=false' exited with code 127
[3/22/2019 17:50:18] [Error] Component files were not generated for negotiate-component component.
There are also error in the customer-messages.log:
Customer Information Messages for blob.sketch
Symbol not found parent name: No parent, class name: symbolInstance, Object name: Terms List, symbolId: DA1E9828-D85E-4298-A0B8-D65E78B60B6C, this object will not be rendered.
Symbol not found parent name: No parent, class name: symbolInstance, Object name: Comments, symbolId: A0DA7DEA-0103-4D3F-9484-D450F0B7AE6A, this object will not be rendered.
In addition to this, we do have a question on the Ignite UI for Angular. Would it be possible to use native Material components in addition to the Ignite UI Angular components?
Wes
