I would like to report a bug about the text area editing feature.
Repro:
1.) Create a text area 2.) Copy some sentence to the text area. e.g.: Fusce rutrum faucibus sem, eget vulputate eros congue ut. Maecenas varius massa at tortor blandit eu rhoncus eros viverra. 3.) Modify the text area size a little bit, for example to not display the last line. 4.) Change the focus from the text area. 5.) Double click on the text area. (In this case all the text inside the text area will be selected.) 6.) Click into text area at the end of the text.
Result: The default bolding selection disappears, but the cursor still remains at the same place
Expected Result: After the deselection the cursor follow the displayed text end point.
p.s.: Is there any possibility to raise a bug to you in a proper place? Not here in the general discussion forum? Thanks!
Zsolt Molnar
Hi Jeremy,
I saw that you had this other thread open. The title is slightly different but is this the same issue you are talking about here? If so, one of our Indigo Studio developers has already replied to you.
I just reinstalled and update with the latest version again, and it still doesn't work. Please assist.
Hi Zsolt,
This issue has been resolved in an update to Indigo Studio. You should download the latest version of the software if you haven't already.
Let me know if you have any further questions on this matter.
We have logged this as a development issue in our internal tracking system with an ID of 128696. As such I have opened a private case for you regarding this issue so that I may link the dev issue to it. This way you are notified automatically once a solution is available. The case number is CAS-105889-X3F8L1. You can view the case here: https://ko.infragistics.com/my-account/support-activity
Zsolt, this is a fine place to share stuff like this. The team will look into it. Thanks for reporting!
