I've created a state that I no longer need. Is there a way to delete it?
Glad to hear that!
The main purpose of that panel is just to navigate between states because it’s quite small. You may notice that if you expand the flow Indigo remembers that and keeps opening in the expanded mode until you choose to minimize it. If you have to manipulate the states (remove / rearrange) you can opt to work with the expanded version for a while.
That said, I understand that in your scenario it would have been nice to have the button available as you just needed to delete a disconnected state. You can publish this idea or vote for existing ones in our user voice website
Let me know if you have more feedback :)
Diego
Niiice. I'd never guess that, actually. I'd welcome this becoming available immediately, not only in the full screen view... ;)
So far, so good - first serious day of prototyping for a serious client went ok. Will keep you updated. Thanks! ;D
Wojtek
Got it! You have to expand that flow diagram with the 4 arrow button next to "Screen Interactions" label. Then, in the full interaction explorer diagram you will be able to select and delete.
Hey, thanks. This would probably work if I have such icon... But I don't :)
Have a look:
Hi Wojtek,
You can also remove the state with the trash button on top left. Please take a look at this prototype that shows that: http://indigo.infragistics.com/prototype/8CH0UVKO
Hope this helps.
