When I set the navigation for an element on a screen to "Other... Go Back", it doesn't work. I navigate to the screen from a previous screen via "Go to another screen or URL" option. It seems that no matter what combination I try, I can't get the "go back" option to work for me. Is there a trick to getting this to work? It seems fairly straightforward so maybe I'm just missing something?
--- Thanks, Jeff
This issue has now been resolved.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
Thanks for the info. I look forward to the next update!
Hello Jeff,
I have created a private case for you, CAS-109287-H7W0L7, in order to track this issue (development id 131571) and notify you when there are changes and the fix is available.
You can access this case at https://ko.infragistics.com/my-account/support-activity
Sincerely,
Valerie
Hi, Jeff.
The dev wizards have spoken, and it's a bug. It will be fixed in the next update, along with other goodies. Thanks for reporting it!
When the update is available, Indigo will inform you when it's available on launch. You can verify whether Indigo is set up to check for updates on launch; look under MENU > HELP & ABOUT > [x] automatically check for updates on startup.
-George
BTW, I forgot to answer your question about "Start". When you create a new screen, it's automatically the START state for that screen. When adding interactions, if you choose the "CHANGE THIS SCREEN" option, Indigo creates a new page state based on the START state, which you can tweak and animate. Indigo automatically names this state based on the action. For example, tapped/clicked ADD TO CART."
For more information, check out the following help topic explaining this concept in better detail.
