For some reason, when I view the screen I'm working on in "working" mode, the repeater I'm using looks fine, but when I Run it, it's spacing out the repeater items-by a lot. Any ideas about what could cause that?
Hi Matt,Last Friday we released a major update for Indigo Studio v1 (now known as Indigo Lite). This update includes a fix for the bug you've reported in this thread.
All you need to do is open Indigo. If you haven't disabled automatic updates (and haven't already installed Update 13), you will be prompted to download and update. If you don't see it there, you can always double-check by going to MENU -> Help and About and clicking on the Check for Updates button on the right side. The current version is Version 1 (Update 13).
Please let us know if you have any other question or feedback.Best regards,ClaudiaIndigo Studio Team
We'll let you know when the fix gets published. In the meantime if you don't use the groups inside the repeater (maybe using container boxes instead?) you should be able to avoid the problem.
Diego
Yep, that's exactly it. I'll keep an eye out for the update!
Hi Matt,
We've spot a similar issue when having groups inside the items of the repeater. Is this your case?
This scenario has been recently fixed internally so it's going to be released soon.
