Hi!
I faced with this problem for the first time after I updated IS. Now I have version 1 (update 14).
The problem: I create a new prototype. In this prototype I create 1 screen with repeater. Then I saved all and run prototype. But IS display error: "Hmm... We can't load this prototype. If this keeps showing, you might want to try out with another browser (though all modern ones are supported) or check our user forums."
It's also repeats when I generate HTML prototype and run it in chrome.
BUT! Prototypes, created in previous versions, running without problems.
Thank you!
I'm glad to tell you that we published an update to Indigo that includes a fix for this issue.
All you need to do is open Indigo. If you haven't disabled automatic updates (and haven't already installed the new update), you will be prompted to download and update. If you don't see it there, you can always double-check by going to MENU -> Help and About and clicking on the Check for Updates button on the right side.
The current version is now Version 2 (update 1) or for Indigo Lite Version 1 (update 17).
Thanks for sending your feedback and please let us know if you have any other question or feedback.
Sincerely,
Valerie
Developer Support Supervisor - XAML
www.infragistics.com/support
Hello Wojtek,
The Indigo team was able to reproduce your issue and will be providing a fix.
I have created a private case, CAS-125052-G1X1R0, to track this issue for you an notify you when it is resolved.
Hello Valerie. Unfortunately I can't share the prototype since it's client's work and I am bound by the nda.
Sorry :)
Cheers
Wojtek
Would it be possible for you to share your prototype with us to help us determine the issue?
If so, you can send the prototype to support@infragistics.com and include attn:Valerie in the Subject.
An update - it actually works well when opened from a web server rather than local drive. Weird...
