40
UI size/scale is different when viewing in run view
When designing UI in work view at 100% zoom (which I assume is actual or true size) the UI elements are exactly the size/scale I want them. When published or previewed in run view the UI appears smaller and not at the same scale as in work view. This is not the expected behavior. I would expect that the size/scale I see in work view would be the same in run view or when published. Why does this happen? How do I make sure the preview and/or publish/final UI is at the same size/scale as what it is in work view at 100% zoom. My thinking was that the zoom operates much like the zoom in Photoshop where 100% zoom is actual size. Maybe this is not the case? Any ideas or help on this would be greatly appreciated.
Sean
