Within the tab element, I'm trying to add a table element to each tab. This seems like it should be pretty simple and straightforward but I haven't been able to get it to work yet. Any help/feedback would be appreciated!
Thanks in advance.
This issue has been fixed in the latest update for Indigo.
If you have Indigo set to automatically check for updates then no action is required to receive this update. Otherwise, when you are using Indigo please go to the “Help & About” screen and press the “Check for Updates” button to update to the latest version and receive the fix.
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
Hello David,
I have created case CAS-134684-Q1J6K3 for you to track this issue for you and notify you of any changes in it status. You may access this case at https://ko.infragistics.com/my-account/support-activity
Sincerely,
Valerie
I knew there was a simple way of setting this up. Thanks, it works. For whatever reason I didn't see the help info in the tab's content area. Once you and George pointed that out, it does exactly as I need.
Thanks again!
Hi Daniel,
There is currently a known issue while dragging tables from the toolbox to containers and tabs.
If you try dropping the table to the design surface and then into the tabitem it should work fine.
Another option would be to edit the tab item, by double-clicking its content, and then dropping the table from the toolbox.
Thanks for the report! The fix will be included in the next Indigo version
Regards, Helena
What version of Indigo Studio are you using Daniel?
In Update 5, it works like so:
Were you trying some other way? Let us know!
You can read more information about update 5 in our blog post.
