Before I submit a bug for this, can I check that I'm not missing anything?
If I create an animation timeline, and at the end I ask it to navigate to a new screen, I can't seem to edit the type of transition. I can change it but it always reverts itself to Push, 300ms. In this case, I actually want 'None' but nothing I change it to sticks.
Steps:
- Create animation
- Press + and select 'Change/Navigate at End'
- Select the screen I want
- Click on the Go To arrow on the timeline, and select 'Edit' from the options
- A transition dialog appears. In the screen-to-screen transition section at the bottom, select anything other than Push
- Then close the transition dialog using the X in the corner
- Press Go To > 'Edit' again and see the transition dialog
- Note that it has reverted to 'Push'
Hello Ross,
We have released a new update to Indigo Studio, in this update we have worked extensively to fix the transition dialog's animation. We believe the changes implemented will alleviate your issue.
If you have Indigo set to automatically check for updates then no action is required to receive this update. Otherwise, when you are using Indigo please go to the “Help & About” screen and press the “Check for Updates” button to update to the latest version and receive the fix.
Please let us know if you have any questions.
Thank you for reporting this behavior. It seems that this is a known issue and it has been logged in our internal tracking system with Development ID 173697. The case CAS-142236-Q7S4Z7 was created for you so you are automatically notified when the fix is released.
