1935
What is the + symbol on "screen interactions" window
Notice on the image that "You are here" is down in the lower right corner, so the plus symbol (shown red circled) doesn't have anything to do with what screen element is active... so what does the plus symbol mean?
  • 1075
    Verified Answer
    Hi David!
    That icon indicates that the interaction is a 'Shared Interaction', so when it's executed it's applied in addition to other interactions that might be applied at the moment. Non-shared interactions (the regular ones), are applied exclusively, you can't have two applied at the same time. Shared interactions are usually use to define hover interactions, or other interactions that can be 'toggled' (ie. interactions where you have one trigger to move forward to the next state, and the 'inverse' trigger to move back; for example, hover in/out, swipe left/right, and so on).
    Check this topic for a detailed description, and let us know if you need any additional help.
    Thanks!
    Best regards,
    Santiago.
    Indigo Studio Team.
