Dear all. I have a panel on my page with two ulrawebtrees. I do not want to see 2 scrollbar on the screen (1 - vertical panel scrollbar, second is ultrawebtree scrollbar). Please find some simple code below . My browser is IE7. Thank you in advance, Sergey
<asp:Panel ID="Panel1" runat="server" BackColor="White" ScrollBars="Vertical" Height="290px" Width="300px" Wrap="False">
<%--first tree--%>
<ignav:UltraWebTree ID="MenuSettingsTree" runat="server" Width="90%">
NodeExpand="OnTreeNodeExpand" NodeCollapse="OnTreeNodeCollapse" />
</ignav:UltraWebTree>
<%--second tree--%>
<ignav:UltraWebTree ID="NavigatorSettingsTree" runat="server" Width="90%">
<ClientSideEvents NodeChecked="ChangeItemVisibility"
NodeExpand="OnTreeNodeExpand" NodeCollapse="OnTreeNodeCollapse"/>
</asp:Panel>
Hi. Ivan, thank you for your kind help. The second link, that you have provided me, was very useful. For addition information: i'm using UltraWebTree release 7.2. I attach the figure how it looks like (2 scrollbars), do not mind the titles of the tree nodes and other stupid information from that free resource: http://keep4u.ru/full/080708/29eb83eb810e11122d/jpg.
I am trying to reproduce the problem, unfortunately to no avail. I am using the latest UltraWebTree release - 8.2. I cannot see the scrollbar of the tree, only of the panel. Could you please send a little bit more information on the problem - this will surely provide additional clues.
You can also check out some answers in the forums on similar problems - hopefully they will provide some help:
http://forums.infragistics.com/forums/p/6126/26589.aspx#26589
http://forums.infragistics.com/forums/p/6466/27752.aspx#27752
Or directly following the search results of this search:
http://forums.infragistics.com/search/SearchResults.aspx?q=scrollbar+ultrawebtree
You can also try with ig:WebPanel (in the Misc assembly) and see if you get better results.
