and the country is a WebCombo that takes data from a database (e.g. all the countries). The thing that I want to do is when the grid is initialized, each webcombo has default value, the value that it is stored in the database. For example:
This is certainly possible. The following link will show you how to do so:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR3.5/html/WebGrid_Display_WebCombo_in_a_Cell.html
When you select a value from the combo, it becomes the cell's value; therefore, you can persist this change to the database.
