Hello.
I get the following error when i do :
UltraWebGridExcelExporter1.Export(grid1);
I am using assembly="Infragistics35.Web.v11.1, Version=11.1.20111.2178 .
I deleted the StyleSetPath="~/ig_res/" , but the same result.
Hope you can help me .. thanks.
Hi Ioan Iulian Bucsa,
I haven't received an update through the case or via email, and so I have closed it.
If you still have questions regarding the UltraGridExcelExporter, feel free to update this forum thread with the details more details.
Thank you for the update.
I have created case number CAS-166113-M8N3R5 which you can use to upload the details I've requested. Alternatively, you can always email support@infragistics.com any attachments as well. If you choose to email your files, please include the case number and my name in the subject field.
Looking forward to your updates.
please give an email that i can send you more info , and then i post here the solution. thank you
Hi Ioan Iulian,
Thank you for posting on our forums.
To fully isolate the cause of this issue and provide you with a solution, we would need additional details regarding the implementation of your UltraWebGrid, UltraWebGridExcelExporter, and web.config file. Please update this thread with an isolated sample and we will be happy to review this further.
