The documentation 2008 Vol1 talks about the sample portal. Where do I find them for Websphere Portal 6.0? I find the xml anf the jar files only.
Krishnan
Hi Krishnan,
The WAR file used as a sample portal in the documentation does not ship with the product.
If you configure your own WAR file with the portlet.xml and the igPortalFilter.jar, jsf-ibm.jar and jsf-portletbridge.jar, as stated in steps 1 and 2 of the documentation (http://help.infragistics.com/Help/NetAdvantage/JSF/2008.1/HTML/JSF_Getting_Started_WebSphere_Portal.html), you will be able to run your own WAR file in the WebSphere portal.
