Hi All,
I am a using a Infragistics TreeView control .
I kept all the nodes in the UltraTreeNode object(let us say "pnode") .
This pnode object is having lot of child nodes .
My problem is , i would like to sort pnode object before adding it to the TreeViewControl.
regards,
Faizal Ahmed.H
o sort the contents of a tree, you invoke the Sort method of the Nodes collection. This method has two parameters. The descendants parameter specifies whether to sort all the nodes in the control, or only top-level nodes. If descendants is true, the control will navigate the hierarchy and sort the children of nodes. The second parameter specifies whether the sorting process will be case-sensitive.In Visual Basic:Private Sub SortAll_Click(ByVal sender As Object, ByVal e As System.EventArgs) _ Handles SortAll.Click Me.UltraWebTree1.Nodes.Sort(True, False)End SubIn C#:private void SortAll_Click(object sender, System.EventArgs e){ this.UltraWebTree1.Nodes.Sort(true, false);}
Could you please send a little bit more information. ASPX declaration, code-behind - anything that can get us started is welcome.
Thanks.
