In my report, I have to put some conditions to check to some columns for special values and based on this I have to add a thick border on the top of that cell only. In this case, I am checking for propName == "ClassCode" and based on the content I am trying to add top border for that cell only (not in all cell for that column).
My problem is when I change the top border, its applied to entire report where ever I am using border. Below is my code:
var dt=string.empty;
private void AddRowCell(ITableRow tableRow, string propName, string dt){
var tableCell = tableRow.AddCell();
tableCell.Borders = bordersStyle;//new Borders(new Pen(new Color(200, 200, 200), (float)0.5, DashStyle.Solid));
//set top border for class code if (propName == "ClassCode") {
if (clsCode != dt) { //change the top border for this cell only tableCell.Borders.Top = new Border(new Pen(new Color(50, 50, 50), (float)4, DashStyle.Solid)); }
clsCode = dt;
IText cellText = tableCell.AddText(); cellText.AddContent(dt);
I am using 2014.2 report.dll. Please help me on this.
I was trying few more things and I found a work around. Basically I have to define all 4 sides of border even though I dont need them.
//this code works fine
tableCell.Borders = new Borders( new Pen(new Color(200, 200, 200), (float)0.5, DashStyle.Solid), new Pen(new Color(200, 200, 200), (float)0.5, DashStyle.Solid), new Pen(new Color(50, 50, 50), (float)2, DashStyle.Solid), //top border new Pen(new Color(200, 200, 200), (float)0.5, DashStyle.Solid));
//this code doesn't work
tableCell.Borders = new Borders(new Pen(new Color(200, 200, 200), (float)0.5, DashStyle.Solid));tableCell.Borders.Top = new Border(new Pen(new Color(50, 50, 50), (float)4, DashStyle.Solid));
Is there any issue in below code which doesn't just change the top border?
