I have added an updaterow method to my webgrid as it was instrcuted in this base knowledge http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9966 . When I run my application, it throws the following message:
Object reference not set to an instance of an object.
case DataChanged.Modified:
// this.UpdateDataMap(e.Row);
updatedatamap.UpdateMddDataMap(Convert.ToInt32(e.Row.Cells.FromKey("LookupRDBID").Value),
e.Row.Cells.FromKey("MapField").Value.ToString(),
e.Row.Cells.FromKey("WMDvalue").Value.ToString(),
e.Row.Cells.FromKey("VariableText").Value.ToString(), e.Row.Cells.FromKey("ElementName").Value.ToString(),
e.Row.Cells.FromKey("PTKVariable").Value.ToString(), e.Row.Cells.FromKey("CCP").Value.ToString(),
Convert.ToDateTime(e.Row.Cells.FromKey("DateModified").Value), Convert.ToDateTime(e.Row.Cells.FromKey("DateDeleted").Value),
Convert.ToBoolean(e.Row.Cells.FromKey("IsLock").Value), e.Row.Cells.FromKey("MDDFileName").Value.ToString());
case DataChanged.Unchanged:
Move combo boxes that are binded to grid outside the update panel.
Then, you will not get that error.
Hello All,
I know, I am posting very late to this thread.
I am facing same problem with webgrid control.
Every mouse movement this error generate and viewed in firefox error console.
For a same location of global "igtbl_globalMouseMove(evnt)"and line if (gs.Element.getAttribute("elementMode")=="resize")
Please let me know, any work around present for eliminate this error.
I am using infragistics grid with 6.3 version.
Thank you in advanced.
It's really hard for us to advise further, since the scenario is complex and there are many controls involved in it. I can suggest some ideas that may alleviate the problem like
- use our version of Ajax Panel - WebAsyncRefreshPanel instead of UpdatePanel,
- use the built-in AJAX in Grid or Tab instead of UpdatePanel),
If these do not work for you, I guess, the best way to proceed is to send a small subset of your project reproducing the issue to our Developer Support folks - they will surely be able to provide additional clues/solution when they see the repro
Developer Support can be reached via this link:
http://ko.infragistics.com/gethelp/default.aspx
I hit the error " 'Element' is null or not an object" on this same line of code. gs.Element is undefined. I have and an UltraWebTab that contains an UltraWebGrid that contain a WebCombo. This error occurs when the UpdatePanel was added, with the panel it does not occur.
if(!evnt)
evnt=event;
if(typeof(igtbl_gridState)!="undefined" && igtbl_gridState)
for(var gId in igtbl_gridState)
var gs = igtbl_gridState[gId];
var scrElem = evnt.srcElement?evnt.srcElement:evnt.target;
if(!ig_isAChildOfB(evnt.srcElement,gs.Element))
Ok, I found it where it throws the error message.
under this function:
function igtbl_globalMouseMove(evnt){ if(!evnt) evnt=event; if(typeof(igtbl_gridState)!="undefined" && igtbl_gridState) { for(var gId in igtbl_gridState) { var gs = igtbl_gridState[gId]; var scrElem = evnt.srcElement?evnt.srcElement:evnt.target; if(!ig_isAChildOfB(evnt.srcElement,gs.Element)) { if (gs.Element.getAttribute("elementMode")=="resize") <== this is the line where throws the message { if(igtbl_button(gId, evnt)==-1) { igtbl_clearResizeDiv(gs ,evnt, true); } } } } }}
and also after the first error I get another error here:
{if(g.Events.XmlHTTPResponse[1]==1)
Any ideas?
